LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Nodes translation restriction (only moving forward)
    • Yuqian TU
      Hello!
      Is there a keyword or a way to constrain nodes (either in a shell/solid element or rigid node set) at X and Y directions that nodes are only allowed to move forward. When the nodes want to move backward, the displacement is set to 0.
      I was thinking about local coordinate system with rigidwall, but didn’t seem to work.
      Thanks a lot!
    • Jim Day
      A couple of possibilities:
      1. Attach a stiff *ELEMENT_SEATBELT and an accompanying *ELEMENT_SEATBELT_RETRACTOR such that the seatbelt resists backsliding and is reeled in as the part moves forward.
      2. To resist backsliding, a feedback control system of sorts could be employed to apply a resisting force.
      For example, here’s an example in which a force is applied to part #1 in accordance with the control law shown below so that it translates to a specified target point.
      Force = -gain1 * (displacement – target) – gain2 * velocity
      The feedback control system is governed by the following keywords which are used to:
      1. define the gains and other pertinent parameters
      2. define the feedback control law
      3. apply the load
      *PARAMETER
      R gain1 0.060000
      R gain2 0.010000
      R target 2.000000
      *DEFINE_CURVE_FUNCTION
      $# lcid sidr sfa sfo offa offo dattyp
      100 0 0.000 0.000 0.000 0.000 0
      $# function
      -gain1*(dx(28)-target) – gain2*vx(28)
      *LOAD_RIGID_BODY
      $# pid dof lcid sf cid m1 m2 m3
      2 1 100 0.000 0 0 0 0
      In *DEFINE_CURVE_FUNCTION dx(28) is used to monitor the x-displacement of node #28 while vx(28) returns the node’s velocity. These responses are updated continuously with the current values as the simulation progresses. The function itself could be a control law that involves any type of model response, such as, nodal forces, accelerations, stresses, etc.
