Noise in impingement system
    • 1829116
      Hello everyone
      I am trying to find out how noisy my impingement system will be using the Acoustic function in ANSYS FLUENT. I used LES model with the fictional timestep to run the simulation as suggested in this tutorial. I was able to get the required results but now I need to model the system with sound insulation to the walls. How I can do that in ANSYS FLUENT?
      Any answer will be appreciated
    • Kalyan Goparaju
      There is no direct way of doing this in Fluent. The workaround however is by changing the wall to a velocity inlet with 0 m/s velocity and by turning on the impedence boundary condition and providing the appopriate inputs. Please refer to the link below for more details on the impedence BC
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/flu_ug/flu_ug_bcs_sec_nrbc.html?q=impedence
      Thanks,
      Kalyan
    • 1829116
      Thanks Kaylan.
      I will look into the solution you suggested.
      Meanwhile, I have an additionalquestion. The first simulation I carried out included on the air part with walls BC kept as default. I received a SPL of around 140 dB. I carried a second simulation but imcluded the solid walls of my system. THe SPL dropped to 150 dB. Are these results accurate? Can ANSYS analyze sound reduction through solid walls?
      Thanks
      Hadi
