October 3, 2023 at 8:54 am
Andrew Carlin
SubscriberHi there,
Is it possible with the chopped fibre composite RVE in material designer to change the fibre cross-section? e.g. to say have e-glass fibres that are triangular, or lobular .etc?
I appreciate you could do this with a basic user defined RVE with a single fibre (or a small amount), but trying to generate and RVE with many randomly oriented, short fibres, would be difficult.
Any help or guidence is much appreciated,
Best,
Andrew
October 6, 2023 at 2:10 pm
Ashish Khemka
Forum ModeratorHi Andrew,
Please see if the following link is of help to you: Changing RVEs size in Material Designer (ansys.com)
Ashish Khemka
- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
- Mesh Element Quality Display Style Not Showing
8808
4658
3153
1680
1470
