Photonics
Photonics
Non linear Aeff in an SOI waveguide ?
    • aeafifi
      How to compute the nonlinear Aeff in an SOI waveguide using FDTD ?
    • Guilin Sun
      Aeff means (modal) effective area? if you have the mode data you can calculate it based on your definition. If you are using FDTD to create such nonlinearity,it is likely that you can use a profile monitor at some location to record the field at the specified wavelength. Please try.
