Materials
Materials
Non-linear analysis convergence with materials having different Young’s Modulus
    • kaushal.21910939
      Hello everyone,
      I am trying to solve a non-linear problem with interaction of two different components having different material properties.
      Material 1 has a Young's Modulus of 205 GPa and YS 645 MPa.
      Material 2 has a Young's Modulus of 190 GPa and YS 190 MPa.
      The solution conveges when Young's Modulus of both materials kept same but doesn't converge when it is kept different.
      I have tried reducing normal stiffness as well as applied contact interface treatment.
    • peteroznewman
      Under Analysis Settings, turn on Auto Time Stepping and set the Initial and Minimum number of Substeps to 100. Taking many small substeps is often a good method to help convergence if you have material nonlinearilty such as plasticity (or hypelasticity).
