October 8, 2018 at 11:55 am
bcho
SubscriberHello Community,
has anyone tried to do a non-linear, transient analysis with infinite elements (Element type: Infin257)? For my problem the solution does not converge for a non-linear analysis.
October 8, 2018 at 12:04 pm
Ashish Khemka
Ansys EmployeeThis element is used for static analysis.
October 8, 2018 at 12:08 pm
bcho
SubscriberThanks for your reply. I found the information that it could be used for transient analysis as well on this website: https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_elem/elem_infindomain.html Is this wrong?
Is there another element I could use to do my analysis? I want to simulate the behaviour of a soil in combination with a non-linear spring on top. -
October 8, 2018 at 12:16 pm
Ashish Khemka
Ansys EmployeeYes, you are right - my mistake: The element supports static, transient, and harmonic analyses.
October 8, 2018 at 12:21 pm
Ashish Khemka
Ansys EmployeeWhat is the error message you see in the Solver Output when the Solution does not converge?
October 8, 2018 at 12:32 pm
bcho
SubscriberThis is the error message I get after the 4th step. The steps 1 to 3 converge.
The value of UX at node 61017 is 131036267. It is greater than the
current limit of 1000000 (which can be reset on the NCNV command).
This generally indicates rigid body motion as a result of an
unconstrained model. Verify that your model is properly constrained.
I tried a static analysis before and it worked fine, so I'm not sure why there should be a rigid body motion. -
October 9, 2018 at 2:25 am
Ashish Khemka
Ansys EmployeeHi,
Thanks for the update. The error message indicates rigid body motion. What did change between static and transient analysis? If it is same model then I am not sure what might be causing this. Also, model may be required for debugging and I cannot d that. If you can describe more on the problem, that may help.
Ashish Khemka
October 9, 2018 at 10:19 am
bcho
SubscriberHi,
Thanks again for your reply.
For the soil I model the quarter of a sphere with solid186 and add infin257 at the outer surface of the sphere. Additionally I apply a spring-mass-system with combin39 and mass21.
For the static analysis I add a load in z-direction. The transient analysis is done by a loop in time with a sinusodial load or an impulse.
So the model does not change between static and transient except for the analysis type and the load.
I tried the following:
linear + transient --> converges
non-linear + static --> converges
non-linear + transient --> does not converge
I added a picture of step 6 when the calculation does not converge and my APDL commands although I'm not sure if it'll be helpful for you since the comments are in german.
Thanks a lot in advance.
Kind regards,
Bettina Chocholaty
APDL commands:
finish
/clear
/PREP7
RM=0.5 ! Lastradius
RB=10 ! Bodenradius
Gx=80000000 ! Schubmodul
NUxy=0.33 ! Poisson Zahl
freq=100 ! Frequenz in Hz
rho=2000 ! Dichte
cs=sqrt(Gx/rho) ! Scherwellengeschwindigkeit
Exx=2*Gx*(1+NUxy) ! E-Modul
lambda=cs/freq ! Wellenlänge
le=lambda/8 ! maximale Elementlänge
lnele=(RM+RB)/le ! Elementanzahl
lneleh=lnele/2
lnelemh=NINT(lneleh)
lnelem=lnelemh*2
!lnelem=48
dt=le/cs ! Zeitschritt
t=(RM+RB)/cs ! Ankunftszeitpunkt Welle an Rand von Modell
RGES=RM+RB
ET,1,SOLID186 ! 3D 20 NODE STRUCTURAL SOLID
MP,EX,1,Exx ! Materialzuweisung
MP,PRXY,1,NUxy
MP,DENS,1,rho
!---Geometrie der Platte !*!
*SET,H,0.4 ! Plattenhoehe [m] !*!
*set,r,5/2 ! Halbe Breite/Länge Fundament
*set,ri,3.75/2 ! Halbe innere Breite/Länge Fundament
! MATERIAL
!---Materialdaten der Platte !*!
rho=0 ! Dichte der Platte [kg/m^3] !*!
nue=0 ! Querkontraktionszahl der Platte !*!
EModul=9710000000 ! E-Modul der Platte [N/m^2]
MP,EX,2,EModul ! E-Modul
MP,NUXY,2,nue ! Querkontraktionszahl
MP,DENS,2,rho,,, ! Dichte
! Angaben für Masseschwinger
m=10000 ! Masse
knl=597000000 ! Fließgrenze-Steifigkeit
Fnl=149000000 ! Fließgrenze-Kraft
K,1
K,2,,RM+T
PCIRC,0,RGES,0,90 ! Kreisfläche
!! für Plattengenerierung
!Pcirc,RM,RM+T/2,0,90
!PCIRC,0,RM,0,90
!Pcirc,RM/2,RM,0,90
VROTAT,all,,,,,,1,2,-90,, ! Kugelvolumen
allsel
vplot
! Unterteilung der radialen Linien
lsel,inve
lsel,s,length,,RGES
lesize,all,,,lnelem,,1 ! Linienunterteilung nach elementzahl
!lesize,all,le,,,,1 ! Linienunterteilung nach Elementgröße
! Unterteilung der Bogenlinien
Csys,2
lsel,s,loc,x,RGES
allsel
csys,0
!!! MASSE-SCHWINGER !!!
!!! Masse-Fdeder-System
ET,10,COMBIN39,,,,1,,1 ! ELEMENT WITH DISPLACEMENT ALONG NODAL z-AXIS
KEYOPT,10,4,1
ET,11,MASS21,,,0 ! MASS WITHOUT ROTARY INERTIA
KEYOPT,11,3,2
R,10,-5,-Fnl,-0.5,-Fnl,0.0,0.0 ! SPRING DATA
RMORE,0.5,Fnl,5,Fnl
!R,11,0,0,m,0,0,0 ! MASS DATA
R,11,m
csys,0
NSEL,All
!NSEL,S,LOC,X,-r+(r-ri)/2
!NSEL,R,LOC,Y,-r+(r-ri)/2
!NSEL,R,LOC,Z,-H
!*GET,n_center1,NODE,,NUM,MIN
!*GET,n_center1,NODE,1,NSEL,,
!NSEL,S,LOC,X,+r-(r-ri)/2
!NSEL,R,LOC,Z,-H
!*GET,n_center2,NODE,,NUM,MIN
!*GET,n_center2,NODE,1,NSEL,,
*GET,knotenanzahl,NODE,,NUM,MAX
N,knotenanzahl+1,+r-(r-ri)/2,+r-(r-ri)/2,-H
NSEL,R,LOC,Y,+r-(r-ri)/2
NSEL,R,LOC,Z,-H
!*GET,n_center3,NODE,,NUM,MIN
!*GET,n_center3,NODE,1,NSEL,,
!NSEL,R,LOC,Y,+r-(r-ri)/2
!NSEL,R,LOC,Z,-H
!*GET,n_center4,NODE,,NUM,MIN
!*GET,n_center4,NODE,1,NSEL,,
NSEL,all
*GET,n_max,NODE,,NUM,MAX
!N,n_max+1,-r+(r-ri)/2, -r+(r-ri)/2,-5*H
!N,n_max+2,+r-(r-ri)/2, -r+(r-ri)/2,-5*H
N,n_max+3,+r-(r-ri)/2 , +r-(r-ri)/2,-5*H
!N,n_max+4,-r+(r-ri)/2, +r-(r-ri)/2,-5*H
!TYPE,10
!REAL,10
!E,n_center1,n_max+1 !Non-linear spring
!TYPE,11
!REAL,11
!E,n_max+1 !Mass
!nummrg,all
!TYPE,10
!REAL,10
!E,n_center2,n_max+2 !Non-linear spring
!TYPE,11
!REAL,11
!E,n_max+2 !Mass
!nummrg,all
TYPE,10
REAL,10
E,n_center3,n_max+3 !Non-linear spring
TYPE,11
REAL,11
E,n_max+3 !Mass
nummrg,all
!TYPE,10
!REAL,10
!E,n_center4,n_max+4 !Non-linear spring
!TYPE,11
!REAL,11
!E,n_max+4 !Mass
!nummrg,all
NSEL,All
nummrg,nodes
nummrg,all
! Meshing
Mat,1
mshape,0,3D ! Elementform
vmesh,1
! Infinite Elements oder Feste Auflager
*GET,NMAX,NODE,0,NUM,MAXD
NPOLE=NMAX+1
N,NPOLE
CSYS,2
ASEL,S,loc,x,RGES
NSLA,S,1
EINFIN,,NPOLE ! Infinite Elements
!d,all,all ! Feste Auflager
ALLSEL
! Symmetriebedingungen
CSYS,0
!NSEL,S,LOC,Z,0
!DSYM,SYMM,Z ! SYMMETRIC CONSTRAINTS,UZ
ALLSEL,ALL,ALL
NSEL,S,LOC,Y,0
DSYM,SYMM,Y ! SYMMETRIC CONSTRAINTS,UY
ALLSEL,ALL,ALL
NSEL,S,LOC,X,0
DSYM,SYMM,X ! SYMMETRIC CONSTRAINTS,UX
ALLSEL,ALL,ALL
!shpp,on
!shpp,summ
! Knoten für Last auswählen
NSEL,All
nummrg,nodes
csys,2
!asel,s,loc,x,0,RM
nsel,s,loc,x,0,RM
csys,0
!asel,r,loc,z,0
nsel,r,loc,z,0
CM,CM_load,node
allsel
!*DIM,displ,Table,17 ! Kraftvektor
!*TREAD,displ,'last','sis',' ',,
!*VPLOt,displ(1,0),displ(1,1)
!!! LAST
NSEL,All
nummrg,nodes
/SOLU
ANTYPE,trans
tend=dt*300
!dt=0.9108e-5
ntime=NINT(tend/dt)+1
!timint,on
!nlgeom,on
EMATWRITE,YES
*afun,rad
*do,itime,1,70 !* Beginn der Zeitschleife
zeit=itime*dt ! Variable 'zeit' definieren
!F,CM_load,fz,1000*sin(freq*2*3.14*zeit)
!D,CM_load,uz,0.5*sin(2*3.14*zeit)
!SF,CM_load,Pres,100*sin(10*2*3.14*zeit)
!F,CM_load,fz,-sin(2*3.14*5)
D,CM_load,uz,displ(zeit)*0.5
*MSG,WARN, itime, ntime, zeit,
*** Step %I von %I Zeit %G
TIME,%zeit% ! Zeit des nächsten Berechnungs-Schrittes
NSUB,10,30,1
SOLCONTROL,On
!NROPT,FULL
!LNSRCH,ON
!CNVTOL,F,,0.05 ! 5% Tolerance
!PRED,on,,on
!NEQIT,500
SOLVE ! selbstredend
save
*enddo
!*** ENDE DER ZEITSCHLEIFEN ***
FINISH ! Ende des Solution-Prozesses
/EOF -
October 10, 2018 at 10:23 am
October 11, 2018 at 8:12 am
Ashish Khemka
Ansys EmployeeHi Bettina,
I may not be able to run your model at my end. May be someone from the group can run the model.
Ashish Khemka
October 11, 2018 at 11:07 am
bcho
SubscriberThanks anyway. I appreciate your help.
December 28, 2018 at 4:56 pm
Augusto13
SubscriberI'm having this same problem. But for a linear trasient analysis:
https://forum.ansys.com/forums/topic/transient-analysis-with-infinite-element/
Bcho, Did you solve the problem?
December 28, 2018 at 5:21 pm
bcho
SubscriberUnfortunately I have not been able to solve the problem. Now I'm using Combin14 Elements for my calculations which seem to work quite good. -
December 29, 2018 at 6:40 pm
Augusto13
SubscriberI realized that your problem converged to a linear analysis with infinite element. What was the boundary condition of your problem?
December 29, 2018 at 8:13 pm
bcho
SubscriberAs I stated before in a comment, the linear Analysis also did not converge as I thought before. It only took longer to diverge.
About the boundary conditions :
I modeled a Part of a sphere and applied symmetry conditions at the plane surfaces and the infinte elements at the spherical surface. -
December 29, 2018 at 8:14 pm
Augusto13
Subscriberinteresting is when I do the modal analysis before and take advantage of its results in the transient analysis ( transient analysis with modal superposition), the problem does not happen. But the results are not influenced by the infinite element.
2120
1347
1118
461
