March 13, 2021 at 8:42 pm
ces182129
SubscriberI am testing a new material composite beam under flexural 2 point loading. i am doing finite element non linear analysis. The non linearity considered are material non linearity and geometric non linearity. My solutions are getting converged. I am getting good stress strain curves in output. S/S curves clearly showing yield and post yield reduce in slope. However the output load displacement curves are not showing any signs of yield, no reduction of stiffness post yield. the L/d curves are showing up same stiffness throughout the load history.
Please guide so that i can get accuracy in L/d curves. Your help is very much needed at this point of time as I have urgency in my project submission..
Thanks in advance
Vaishali
March 15, 2021 at 8:33 pmJohn Doyle
Ansys EmployeeFrom which layer are you extracting the stress-vs-strain data? How significant is that layer to the overall stiffness of the composite? Could it be that the layer(s) that are carrying the primary load are still linear elastic? nViewing 1 reply thread- You must be logged in to reply to this topic.
2726
2148
1359
1150
462
