October 6, 2017 at 6:58 am
inaamqazi
Subscriber1) what would constitute appropriate boundary conditions for a line model . I have applied uy and rotz at one end , ux at the top end, and symmetry boundary conditions on z axis.I have modelled half the length of the column But the non linear solution is terminating even if i increase the substeps significantly from 100 to 1000. I want to consider only geometric non linearity .I am solving in apdl
October 11, 2017 at 10:23 am
ding
SubscriberCan you give me your apdl commands for detailed problems or give me some model pictures ?
October 11, 2017 at 1:06 pm
inaamqazi
Subscriber/NOPR ! Suppress printing of UNDO process
/PMACRO ! Echo following commands to log
FINISH ! Make sure we are at BEGIN level
/CLEAR,NOSTART ! Clear model since no SAVE found
! WE SUGGEST YOU REMOVE THIS LINE AND THE FOLLOWING STARTUP LINES
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
/GO
/PREP7
ET,1,BEAM188
KEYOPT,1,1,0
KEYOPT,1,2,0
KEYOPT,1,3,3
KEYOPT,1,4,0
KEYOPT,1,6,0
KEYOPT,1,7,0
KEYOPT,1,9,0
KEYOPT,1,11,0
KEYOPT,1,12,0
KEYOPT,1,15,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,33500
MPDATA,PRXY,1,,0.15
SECTYPE, 1, BEAM, RECT, , 0
SECOFFSET, CENT
SECDATA,1500,5000,0,0,0,0,0,0,0,0,0,0
N,1,0,0,,,,,
N,101,0,4400,,,,,
FILL,1,101,99, , ,1,1,1,
/ZOOM,1,SCRN,0.341257,-0.888843,0.351177,-0.938430
FLST,2,2,1
FITEM,2,1
FITEM,2,2
E,P51X
/AUTO,1
/REP,FAST
/ZOOM,1,SCRN,0.356137,-0.898760,0.385896,-0.935950
FLST,4,1,2,ORDE,1
FITEM,4,1
EGEN,100,1,P51X, , , , , , , , , , ,
EPLOT
/AUTO,1
/REP,FAST
FLST,2,1,1,ORDE,1
FITEM,2,1
/GO
D,P51X, , , , , ,UY,ROTZ, , , ,
FLST,2,1,1,ORDE,1
FITEM,2,101
/GO
D,P51X, , , , , ,UX, , , , ,
DSYM,SYMM,Z, ,
FINISH
/SOL
FLST,2,1,1,ORDE,1
FITEM,2,101
/GO
F,P51X,FY,-1
ANTYPE,0
PSTRES,1
/STATUS,SOLU
SOLVE
FINISH
/POST1
PLDISP,1
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/AUTO,1
/REP,FAST
/DIST, 1 ,1.082226,1
/REP,FAST
/REP,FAST
FINISH
/SOL
ANTYPE,1
BUCOPT,LANB,5,0,0,CENTER
MXPAND,5,0,0,0,0.001,
/STATUS,SOLU
SOLVE
FINISH
/POST1
SET,LIST,999
SET,,, ,,, ,1
/REPLOT
SET,LIST,999
SET,,, ,,, ,1
SET,LIST,999
/USER, 1
/REPLO
/REPLO
FINISH
/SOL
ANTYPE,0
FLST,2,1,1,ORDE,1
FITEM,2,2
/GO
F,P51X,FX,3600000
/PSF,PRES,NORM,2,0,1
/PBF,DEFA, ,1
/PSYMB,CS,0
/PSYMB,NDIR,0
/PSYMB,ESYS,0
/PSYMB,LDIV,0
/PSYMB,LDIR,0
/PSYMB,ADIR,0
/PSYMB,ECON,0
/PSYMB,XNODE,0
/PSYMB,DOT,1
/PSYMB,PCONV,
/PSYMB,LAYR,0
/PSYMB,FBCS,0
/PBC,ALL, ,1
/REP
/ZOOM,1,SCRN,0.283175,0.813653,0.376187,0.650922
/PBF,DEFA, ,1
/PSYMB,CS,0
/PSYMB,NDIR,0
/PSYMB,ESYS,0
/PSYMB,LDIV,0
/PSYMB,LDIR,0
/PSYMB,ADIR,0
/PSYMB,ECON,0
/PSYMB,XNODE,0
/PSYMB,DOT,1
/PSYMB,PCONV,
/PSYMB,LAYR,0
/PSYMB,FBCS,0
/PBC,ALL, ,1
/REP
FLST,2,1,1,ORDE,1
FITEM,2,101
/GO
F,P51X,FY,-2500000
ANTYPE,0
NLGEOM,1
NSUBST,2000,0,0
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,1
NEQIT,2100
RESCONTRL,DEFINE,ALL,ALL,-1
/STATUS,SOLU
SOLVE
FINISH
/POST1
PLDISP,1
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/AUTO,1
/REP,FAST
/EFACET,1
PLNSOL, U,SUM, 0,1.0
! SET,LIST,999
SET,,, ,,, ,205
/REPLOT
FINISH
/POST26
FILE,'file','rst','.'
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
FILLDATA,191,,,,1,1
REALVAR,191,191
/REP,FAST
/REP,FAST
/REP,FAST
NSOL,2,1,U,X, UX_4,
STORE,MERGE
RFORCE,3,1,F,Y, FY_3
STORE,MERGE
FINISH
/AUX12
FINISH
/POST26
NUMVAR,200
FILLDATA,191,,,,1,1
REALVAR,191,191
XVAR,2
PLVAR,3,
XVAR,2
PLVAR,3,
NUMVAR,200
FILLDATA,191,,,,1,1
REALVAR,191,191
XVAR,2
PLVAR,3,
FINISH
/POST1
PRNSOL,U,COMP
)/GOP ! Resume printing after UNDO process
)! We suggest a save at this point
October 11, 2017 at 1:07 pm
inaamqazi
Subscriber@ding ..can you share your research gate profile so that we can remain in touch.
With Regards
Inaam
2120
1347
1118
461
