June 7, 2020 at 1:26 pm
OguzhanA
SubscriberWhat does reduce, constant mean in the Stabilization option in non-linear controls? (similarities and differences)
What happens if the energy dissipation and stabilization force limit is high? Need to get a certain value?
June 8, 2020 at 1:28 pm
SaiD
Ansys EmployeeHi,
For your first question: go through the material under "Stabilization"
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_nl_static_transient.html
For your second question, if the energy dissipation ratio is high, the resultant stabilization force is high and hence will result in a stiffer response. We use these techniques (either energy dissipation factor or damping factor) to add a small numerical force to stabilize the simulation. This is not a physical force, but a numerical one. So ideally it should be as small as possible so that it doesn't change the physics of the problem. You can go through the material under "Controlling the Stabilization Force" to understand it further:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_str/Hlp_G_STRUNST.html
Hope this helps,
Sai
June 9, 2020 at 5:55 am
OguzhanA
SubscriberHi Sai ,thank you .
Regards
OguzhanA
3778
2579
1825
1242
598
