September 10, 2019 at 6:46 pm
jvardaman
SubscriberI have been in contact with someone previously about identifying temperature mismatch between measured and model results in ANSYS Mechanical. I have discovered something else within the Mechanical model that is not providing accurate results. As you can see in the image attached, I ran a simple experiment where I heated some high density polyethylene (HDPE) in an oven and then cooled it down in ambient air. I included my current model results as well. The measurements show there is a region of heat transfer change in the HDPE material around 120-130C. The model does not account for this. I had to change the convection film coefficient to get the model to reach the same temperature as the measured. Is there someone with more intimate knowledge of the Mechanical program that could help with this issue? I would like to continue using this program, but it is consistently producing inaccurate results. Thank you. -
September 10, 2019 at 11:20 pm
September 16, 2019 at 7:33 pm
Chandra Sekaran
Ansys EmployeeThat knee like behavior can occur due to latent heat where temperature is not changing much but some kind of phase change is happening. In ANSYS for the transient thermal you can use specific heat & density or use enthalpy. In either case the latent heat should be accounted for. I wonder if this is included in this model.
https://www.mdpi.com/2076-3417/7/7/722/pdf seems to show a phase change in HDPE type material at 130 C. So may be this is the issue?
September 16, 2019 at 7:52 pm
jvardaman
SubscriberHi, CS
The phase change does indeed happen around those temperatures, and I also believe the 'knee' is due to phase change. I have manually inputted what I am told are the correct specific heat and density values. I have never seen the knee replicated in the simulation results, so I cannot verify that the model is taking phase change into account. Obtaining the correct correct film coefficient is another matter that throws values way off. -
September 16, 2019 at 8:35 pm
Sandeep Medikonda
Ansys EmployeeHi, Just to add.
Please see the following verification examples
especially this particular one:
Also, please see this link below for enthalpy vs temperature data of HDPE
2068
1289
1106
459
