June 6, 2023 at 2:05 am
Wender Daniel
Subscriber -
June 7, 2023 at 11:28 pm
Guilin Sun
Ansys EmployeeSomehow the reply yesterday did not show here.
Since EME does not enforce the reciprocity, due to numerical errors of discretization and the field continuity such difference can happen. Further reducing the difference takes more time from converging testing, and it is not obvious which factors dominate this.
June 11, 2023 at 8:02 pm
Wender Daniel
SubscriberHi Giulin, thank you for your reply!
Changing the EME tolerances can reduce the difference?
Best regards
June 12, 2023 at 3:50 pm
Guilin Sun
Ansys Employeehttps://optics.ansys.com/hc/en-us/articles/360034917533-Understanding-EME-error-diagnostics
those tolerances are subtle to define, but can be helpful. At the same time you will need to check the diagnosis and see if it violates some physics too much.
Since the difference of the non-reciprocity is small, it can be challenge to reduce to very small level without trial and error.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7724
4484
2957
1441
1322
