March 15, 2022 at 3:55 am
vinnakbm
SubscriberHi
I successfully completed a transient analysis and wanted to rerun it by changing one parameter (RPM) in CFX. I did a save-as to the project file in workbench and reset the solution data. Then changed the RPM in CFX-Pre to run the simulation again with lower RPM. When I'm starting the solver, I am getting a non-zero exit code : 25. See screenshot below. Any ideas on how to troubleshoot are greatly appreciated!!
Thank you
March 15, 2022 at 10:56 amDrAmine
Ansys EmployeeCan you please insert the screenshot in your text?
Will the error happen if you start from scratch? Run the case outside of the Workbench?
March 15, 2022 at 1:21 pmvinnakbm
SubscriberThank you for the suggestions. The error was attached in my previous message. Here it is again. I archived the file and started the solver through workbench on a different computer and it was running fine. I have been using the previous computer for a while without any problems and there is still plenty of disk space. I wonder what changed.
March 16, 2022 at 10:55 amDrAmine
Ansys EmployeeBit hard to know the cause. For that reason: if you take the definition File and try to run it outside the Workbench using the Ansys CFX Solver / Launcher: will it result in issues?
March 16, 2022 at 1:47 pmvinnakbm
SubscriberI started the solver through workbench using the archived file on a different computer and it ran fine. I got the results as well. Thank you
March 17, 2022 at 10:18 amDrAmine
Ansys EmployeeWelcome!
Viewing 5 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
