Nonlinear adaptive regions
    • Lovisa Svanborg
      Hi!
      I got this message:
      I have mesh the hyperelastic part with body sizing then I have choosed that part for nonlinear adaptve regions. I have body scoping. What can I do about this?
      Regards Lovisa
    • Akshay Maniyar
      Hi Lovisa,
      NLAD causes mesh changes during the course of the solution process, so there are some result scoping limitation which you can found at below Ansys help link.
      Nonlinear Adaptive Region | post processing limitations
      Also, you try suppressing all the output results and running the model. Then, you can unsupress results one-by-one and evaluate the results to find out which output result has issue.
      Thanks,
      Akshay Maniyar
