Nonlinear analysis settings for a bending test
    • Jonathan974
      Hi everybody,
      I finally managed to model my 4 points bending test as I wanted i.e with frictionless contacts for the supports of my sandwich beam but my goal would be to have a non-linear force-displacement curve output (polynomial curve, it is what I obtain by experiments) however by solving the problem with the large displacement option active I just get a straight curve...
      My question would be: what settings do I need to activate to get the desired result?  I've tried to deal with Newton-Raphson option but I'm not sure about what I am doing,
      Thanks a lot, J.
    • peteroznewman
      Does your experimental 4-point bending test take the beam past the elastic range and cause a failure?  What type of failure occurs, does the core fail in shear or does the adhesive bond between the core and the face sheet fail?
      For whichever failure mode occurred in the experiment, you have to include that failure behavior in the simulation.
    • Jonathan974
      So yes I took the beam past to the elastic range and it causes a core failure, so I look option on ACP and I found the Composite Failure Tool, do I need to add nonlinear properties on core and face sheets I use ( that I don't have), or just the composite tool is enough to get the curve I want ?
      Furthermore I've found this post you've made : https://forum.ansys.com/forums/topic/i-want-to-see-the-failure/ but I guess this is not appropriate here because of composites ?
      Thanks a lot J.
    • jj77
      There are specific damage initiation criteria and evolution law capabilities for composites in Ansys that you can use for this.
      See this tutorial on how to use that to model damage in composites:
    • Jonathan974
      Thanks for answering,
      I looked at the tutorial and this tutorial and I guess this is not really appropriate for my case because to use damage initiation criteria and evolution law capabilities I need to add orthotropic strain/stress limit for tension and compression and this is not my case ..
      Actually, I would like to add a sandwich failure criteria on my core ( core failure) to get then the same vertical displacement that i get by experiments(polynomial) instead of a linear one,
      I've found this topic but the link for Sandwich failure is not working .. https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/acp_ug/acp_failure_analysis.html
      Thanks in advance J.
    • peteroznewman
      Any documentation you can find on that site can also be found in your current version of ANSYS Help.
      What is the core material in your case?  Do you have core shear test data from a test like this.
    • jj77
      There is something in ACP called core failure but that is a failure criteria (does only tell you if it has failed). Never used this so I can not comment on it. See the proper documentaion in your help manual (not the internet).
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/acp_ug/Core_Failure.html
      Even though these are anisotropic damage initiation and evolution laws one can just set all the directions the same and you get isotropy which you might have.
    • Jonathan974
       Thank you both for answers,
      Here are results I obtain with Large deflection option ON,
      Core is a honeycomb core and I have the 9 coefficients of the stiffness matrix (E,G,nu) I furthermore added a type ply : Honeycomb core. even for face sheets I have the 9 coefficients of the orthotropic elastic materials.
      Does it exist a bending strength limit I can add to make the blue curve like the orange one  ? I am a bit lost I admit
      Thanks for help !
    • ismailhakki
      Hello JonathannCould you solve your problems? If yes, can you share your advices? I have also another problem. Your solving might be also a solution for usnThanks in advancen
    • ismailhakki
      n
Viewing 9 reply threads
