Tagged: apdl, cyclic-loading, hysteresis-loop, material-nonlinearity
January 19, 2023 at 3:17 pm
Yaseen Sh
SubscriberHello
In Ansys APDL. I have a plane 183 element with dimensions 100x50 m. Subjected to a harmonic displacement at three different edges (the left, right and the bottom). Theses edges are constrained in the vertical direction.
The analysis type: Transient, with steps 0.02
Using a linear material, I have got a cyclic response (for point A for example). However when I use a nonlinear model (TB,BISO) the analysis stops (I have tried different models and I got the same). and I can not get any plastic strain as well
I want to show the hysteretic loop for this problem.
My questions:
1. Why the analysis stops when using the nonlinear material? and the strian is just elsastic?
2. How can I plot the hysteretic loops?Thanks
January 25, 2023 at 4:38 pm
Bill Bulat
Ansys EmployeeIf you are running MAPDL interactively, what message(s) do you see in the output window? The MAPDL output window looks like this:
If you are instead solving the model in batch mode, the message(s) will be in the output file. Is the frequency of excitation at or near a natural frequency of this very large plate? If not (if there is no dynamic amplification) then a static analysis should suffice (there would in this case be no need to solve as a transient). Is it your intention to predict either of the two phenomena (ratcheting or shakedown) using a Chaboche material model?
Kind regards,
Bill
January 29, 2023 at 12:00 pm
2120
1347
1118
461
