September 6, 2023 at 7:20 pm
Wing Ko
SubscriberI was wondering if there is more information about simulating nonlinear effects in FDTD/varFDTD. I checked that there are different material models I can use but is there a guide on which models are best suited for what applications? Also, I do not see the material models do not account for two photon absorption or the free carrier effects, so is there a model that can do that as well?
Thank you!
September 6, 2023 at 7:51 pm
Devika Padmakumar Nair
Ansys EmployeeHello,
These are the examples available in nonlinear optical: Nonlinear optics - list of examples – Ansys Optics
You can try Chi3 Ramman model and further information available here: https://optics.ansys.com/hc/en-us/articles/360034394734
Also, you can vote new features, and file your feature request here:
Hope these helps.
Thanks and regards
Devika
September 6, 2023 at 9:43 pm
Wing Ko
SubscriberHi Devika
I did look over those examples but I was wondering if there is better documentation on how Lumerical implements nonlinear effects.
Thank you!
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4504
2971
1449
1322
