August 26, 2019 at 8:29 am
Venugopalb
SubscriberHello all!
I am doing nonlinear buckling analysis in a shell. sometimes, workbench solves the model and give a converged solution. But, In some cases, it is converging up to yield point. After that, it shows a convergence error. How to resolve this problem?
Here I am using geometric imperfection of linear buckling modes 1 and 2.
Please give some guidelines.
Thanking you
August 26, 2019 at 7:22 pm
Sandeep Medikonda
Ansys EmployeeWhat specific error message is reported in the solver output?
What type of material behavior are you providing?
August 27, 2019 at 10:41 am
August 27, 2019 at 1:47 pm
Sandeep Medikonda
Ansys EmployeeSo, you are adding the displacements from a previous analysis? what is the reasoning for that? Also how far into the simulation do you proceed and what does the force convergence look like?
In multi-linear plasticity, you need to specify Stress vs Plastic Strain....So at zero plastic strain, you would have to start at yield...this is one clear mistake.
Once you fix that, I would also look at the plastic strain in the model....It is very likely that you are exceeding what you are specifying here as the max. plastic strain...beyond this point ansys does not extrapolate and your tangent stiffness might be zero which could be causing issues....I would use the slope of the last 2 points and add a dummy point with a very high plastic strain value or use a bi-linear elastic-plastic material model....
August 28, 2019 at 4:00 am
Venugopalb
SubscriberHello sir!
1. I added displacements of linear buckling analysis to introduce imperfection in the model.
2. We are feeding the stress-strain curve to Ansys to predict the behavior. but you stated that for 0 plastic strain it should start with a yield point of stress. I think there is no difference. How can I calculate the strain with respect to stress after a yield point?
3. Is it necessary to add yield and ultimate strength data when we feed multilinear Isotropic hardening?
4. How do you say that plastic strain exceeded the maximum value?
August 28, 2019 at 5:10 am
August 28, 2019 at 2:12 pm
Sandeep Medikonda
Ansys EmployeeYes, subtracting elastic strains is how I would do.
I am pointing out a typical problem with multi-linear plasticity models based on experience. I am not sure if it is the cause of the problem in your case.... But check for plastic strain and see if has exceeded the max value....because it is a buckling problem my guess is that it has...
Either way, Consider adding some stabilization and see if it helps with convergence....start with a small value such as 5e-02 or 0.1 even....
August 28, 2019 at 2:36 pm
Venugopalb
SubscriberThank you, Sandeep!
yes. It is a buckling problem.
1. How can I check plastic strain exceeds the maximum value or not?
2. I have given material data as Young's modulus, Poisson's ratio, yield strength, ultimate strength, and Multilinear strain hardening. Is it enough?
3. As per your suggestion, If I add Stabilisation, it may affect the result. Right?
August 28, 2019 at 2:43 pm
Sandeep Medikonda
Ansys EmployeeRight-click on the solution and add an equivalent plastic strain
Yes, you need to check for the stabilization energy and make sure it is small enough.
August 28, 2019 at 2:54 pm
Venugopalb
SubscriberYes sir.
I will try it.
/prep7
UPGEOM,0.5,1,1,file,rst,
UPGEOM,0.5,1,2,file,rst,
cdwrite,db,file,cdb
In the above mentioned imperfection code, what will be the maximum value as we can give? Give some commands regarding this.
Thanking you for our quick reply.
2078
1293
1106
459
