Normalized values in a contour
    • Jormungandd
      Hello, I am new to ANSYS Fluent.
      How can I draw a contour with a legend with normalized values?
      I have this:
      And I would like this:
      If you create a custom field function (User Defined tab) you can do this.
      The function would be   static temperature / 516.15     and you can give it a sensible label when you create it.
      Plot that function rather than the static temperature you've used.
    • Keyur Kanade
      Please see image below of what Rob suggested.
      If this helps you , please mark this as 'is solution' to help others on forum.
    • atulsingh92
      Kindly also tell abou this, if there is an xy plot?
      The plot is temperature vs a line on the center in the middle of the pipe, perpendicular to the pipe axis, and touching ends of the wall (not shown here-unable to load because of error)
      I want to plot Temperature Vs position with direction vector on the x axis.
      Is there a way I could non-dimensionalize this position on the x-axis with the diameter of the pipe?
      And then plot the xy with temperature..
      Kindly also suggest chaning curves and axis of theses xy plots with TUI?
      You may need to export the data and use Excel: Fluent was designed to output data and not non-dimensionalise locations.
Viewing 4 reply threads
