LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Not able to 3d mesh a chassis model
    • sankarsuresh01
      I'm trying to mesh a 3d chassis model of a car. The model has been imported from solidworks, and has been made using the weldments and trim/extend feature. As of now, I'm able to mesh the model without applying boolean or without grouping all the chassis members as a part. But, performing the explicit dynamics crash test with this configuration, is taking a lot of time, and also the results are not right. The stress /strain is 0, and the deformation doesnt take place. If I try meshing the model after grouping as a part, the mesh generation takes a long time, but never gets meshed. It just keeps on going. How should I proceed? Thanks.n
    • peteroznewman
      nThere are many discussions you should read to learn how to build this model.nhttps://forum.ansys.com/discussion/1029/getting-zero-maximum-and-minimum-stress-value-in-explicit-analysis/p1n
