TAGGED: 3d-mesh, 3d-meshing, mesh-generation, meshing, model-part
December 11, 2020 at 10:41 am
sankarsuresh01
SubscriberI'm trying to mesh a 3d chassis model of a car. The model has been imported from solidworks, and has been made using the weldments and trim/extend feature. As of now, I'm able to mesh the model without applying boolean or without grouping all the chassis members as a part. If I try meshing the model after grouping as a part, the mesh generation takes a long time, but never gets meshed. It just keeps on going. How should I proceed? Thanks.nn -
December 11, 2020 at 1:41 pm
Rahul Kumbhar
Ansys EmployeeIt would be difficult to comment without looking at geometry. Here is my suggestion. nAfter boolean, use 'Check geometry' in Spaceclaim to see if it shows any issue. If some bodies touching in very small region like two curved tagent surface and if boolean happens on these bodies, it creates thin region which is problematic for meshing. Check thoroughly all contacting regions where boolean takes place. Create sufficient large contacting area so boolean happens properly. Also check the small features in the geometry. Set your defeaturing tolerance in Mesh smaller than the smallest featuresnTurn off the defeaturing option in MeshnIf you are doing grouping, check the imprints on each body. Looks for the smallest faces. Again set the defeaturing tolerance smaller than these faces/thickness etc.n -
December 12, 2020 at 5:10 am
sankarsuresh01
SubscriberThank you. I think it was due to few intersecting bodies, which were not detected when i meshed it as separate parts... Fixed them... Thanks n -
December 12, 2020 at 12:06 pm
SubscribernI recommend you use a surface model of the frame. nA solid model of the frame will not be useful to for meshing and simulation.n -
December 12, 2020 at 2:30 pm
sankarsuresh01
Subscriber@sankarsuresh01 I recommend you use a surface model of the frame. A solid model of the frame will not be useful to for meshing and simulation.https://forum.ansys.com/discussion/comment/100127#Comment_100127
Ok... will do.. Thank you @peteroznewman, n
- The topic ‘Not able to 3d mesh while converting solids to one part’ is closed to new replies.
- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Local mesh refinement with targeted edge lengths at specified areas
- Fluent Meshing Batch Mode – Problems workflow commands
8808
4658
3153
1680
1470
