Discovery Import
Discovery Import
Not able to get make connection to Ansys subscription
    • grant.heathman
      I have installed Discovery Live and setup the licenses on the license page and invited users that all looks good.  But when I start Discovery Live, I get this error:   Ping looks good to ansys server Also the Curl did not give me any output?   so what gives?  Please let me know   THX
    • grant.heathman
      Also here are the log files, nothing in the temp dir that I could see...
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • grant.heathman
      Did these steps no help...
    • Brian Bueno
      Hi Grant,
      Can you just confirm that curl.exe is located in C:tmp please?  If that is a temp directory on your PC, you may want to move it elsewhere.
      Also, please make sure that you launched the command prompt using Run as Administrator.
      If it runs correctly, curl.exe should generate a couple dozen lines of output in the command prompt window.
    • grant.heathman
      Yes to all your questions see below   So what gives?
    • grant.heathman
      Can you please let me know what needs to be done next?
    • Brian Bueno
      A node locked license has been requested
Viewing 6 reply threads
