April 8, 2018 at 8:59 pm
ca
SubscriberI downloaded the trial of Discovery, so the shortcut icon for Discovery Live and Discvovery SpaceClaim appeared on my desktop. I can't open either one in admin or user mode. Nothing appears on the screen. I spent a couple hours downloading certificates, resetting firewalls, listing exceptions and manually loading the certificate numbers in command mode. Still can't open the software so I can sign in. I have tried all suggestions. Is this a lost cause?
April 9, 2018 at 7:36 am
Naresh Patre
Ansys EmployeeHello CA12
- Can you try disabling antivirus while launching Discovery products and see if it helps?
- If above option does not help, can you open Command prompt in administrative mode and execute following command and let me know what it returns:
April 9, 2018 at 6:28 pm
ca
Subscriberhi, i tried disabling antivirus, still can't open the software, not even to sign in. I ran the command in admin command prompt, and got:
Microsoft Windows [Version 10.0.16299.309]
(c) 2017 Microsoft Corporation. All rights reserved.C:WINDOWSsystem32>ping ansys-fno.flexnetoperations.com
Pinging sc-fnoweb.flexnetoperations.com [64.14.29.39] with 32 bytes of data:
Reply from 64.14.29.39: bytes=32 time=81ms TTL=241
Reply from 64.14.29.39: bytes=32 time=83ms TTL=239
Reply from 64.14.29.39: bytes=32 time=75ms TTL=241
Reply from 64.14.29.39: bytes=32 time=75ms TTL=241Ping statistics for 64.14.29.39:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 75ms, Maximum = 83ms, Average = 78msC:WINDOWSsystem32>
April 10, 2018 at 7:48 am
Naresh Patre
Ansys EmployeeCA12 Can you send following files:
- log file starting with "ansysls_client" located at %temp%/.ansys folder
- Below files from folder "
ANSYS Inc"
- install.log
- install_licconfig.log
- install.err (if it exists)
Also, are you getting any error message while launching Discovery products? If yes, can you send its snapshot?
April 10, 2018 at 3:06 pm
ca
SubscriberI sent the files requestyed by replying to your email. No, I'm not getting an error message, when I try to open the Discovery or the SpaceClaim software, nothing happens, no windows, no messages. Only the hourglass for three seconds then it disappears. I've tried both user and Admin modes. Thx for help.
April 12, 2018 at 4:29 am
ERab
Ansys EmployeeCA12 This happened to one user and turned out their GPU did not meet the minimum requirements of 4GB on the GPU. Please verify your system meets the minimum requirements and run the compatibility utility found on this page please. Ansys Discovery Hardware Requirements (2022 R2)
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
- Unexpected graphics error
5340
3345
2471
