November 3, 2023 at 5:46 am
Abinav Balachandar
Subscriber" Port refinement, process hf3d error: Port 1 does not have a solved inside material on either side.. Please contact Ansys technical support. "
November 3, 2023 at 6:11 pm
Faezeh Ladani
Ansys EmployeeHi Abinav,
Have you set the proper boundary assignment? For example, a Rad boundary around everything where the waveports are sitting right on the boundary.... This assignment also helps to create the vacuum or air material inside the solve region.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8770
4658
3151
1678
1456
