November 11, 2019 at 6:19 am
sherwin684
SubscriberI am having trouble on splitting a surface using the split tool. By default it shows me the position where I want to split. By using the percentage of the surface we want to split, we can do so. But the problem is, I am not able to split the surface according to the dimension I want. Since the maximum precision of the percentage is 0.1, i am able to split according to the suggested dimensions only.
I need to change the splitting based on the dimensions. How do i do it ?
I need a split at 30.44 but the closest I am able to get is 30.39. If i go to 43.4%, it is greater than 30.44.
November 11, 2019 at 7:18 am
Subashni Ravichandran
Ansys EmployeeHello,
You can press tab/ click on the dimension and enter the required value instead of entering the percentage.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5382
3363
2471
1310
1022
