March 28, 2021 at 10:30 am
mahesh2444
SubscriberI am performing reflectarray simulations using Domain solver.and Horn are separated by creating FE-BI boxes surrounding each of them. For clear picture of my simulation setup see this
Video summary
"HFSS using Hybrid technique is implemented here. The entire simulation domain is divided into two FEBI region and we can avoid mesh between horn antenna and reflectarray. Hence reducing simulation time and memory consumption."
When I tried to simulate the above described setup, only first machine in the list is getting used for adaptive meshing and second machine remains idle. Eventually, this causes "Out of memory" issue leading to abrupt termination of simulation. I am using ANSYS EDT 2021 R1 for performing my simulations.
How could I make my two machines to be used for adaptive meshing simultaneously just happened with the case of direct solver ? Please help me by sharing if there is any work around method to solve my problem.
Thanks
Mahesh
April 1, 2021 at 1:12 pmVivekKamble
Ansys EmployeeHelloArray, nFor adaptive meshing, the first machine is used by default. The problem Out of memory is due to the first machine does not have enough memory to mesh the model. nunless the meshing is completed simulation will not proceed further, so your second machine will not get used, to get the issue resolved please try changing the mesh size and reducing the number of passes.nnThanks,nViveknnApril 1, 2021 at 1:32 pmmahesh2444
SubscriberHello @mahesh2444, For adaptive meshing, the first machine is used by default. The problem "Out of memory" is due to the first machine does not have enough memory to mesh the model. unless the meshing is completed simulation will not proceed further, so your second machine will not get used, to get the issue resolved please try changing the mesh size and reducing the number of passes.Thanks,Vivekhttps://forum.ansys.com/discussion/comment/113655#Comment_113655
Hello @VivekK, nIs there any method to solve this other way around in HFSS ?nIn case of the example file which involves solving a large helical antenna with a radiation box the adaptive meshing also gets distributed across machines. I am wondering if there is any trick in HFSS to make this simulation to be performed in same manner.nApril 1, 2021 at 1:44 pmVivekKamble
Ansys EmployeeHi Mahesh,nYou can use the Domain Decomposition method and setup HPC to solve a large problem such as a helical antenna. HFSS automatically apportions the helical antenna design into domains and solves them by separate processes. See the discussion associated with the helical antenna example project that can be accessed with File > Open Examples nPlease look at section Enable Domain Decomposition in the HFSS help document.nnRegards,nViveknApril 1, 2021 at 1:48 pmmahesh2444
SubscribernWhen the setup shown in figure is made in HFSS by default it was using Domain Decomposition Solver only. So that's why I shared this query in forum to understand why it was behaving differently although the same solver has been used.nViewing 4 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2620
2098
1327
1110
461
