May 25, 2022 at 2:45 pm
tomas.monopoli
SubscriberI am running HFSS on a virtual machine.
Everything was working ok.
Today when I try to run an analysis, I get the following error:
not enough HPC parallel licences 12/4
Does anyone know what could have happened?
Thank you!
May 26, 2022 at 2:59 pm
George Karnos
Ansys EmployeeHow many HPC licenses are available to be used?
You can perform a license status by running:
C:\Program Files\AnsysEM\v221\Win64\licensingclient\winx64\ClientSettings\ClientSettings.exe
What version are you running?
Windows or Linux?
Are there any errors listed in the *.out files under %TEMP%\.ansys directory?
In AEDT, if you look at: Tool->Options->General Options, Verify that Use Electronics Pro, Premium, Enterprise product licensing is checked
September 29, 2022 at 9:06 pm
tomas.monopoli
SubscriberHello,
I've just started using the VM again and I have re-encountered the same problem.
The version I am running is 2022R1 on Linux (Centos7).
What would be the equivalent of %TEMP%/.ansys for the linux build?
This option is indeed checked.
Also I have installed ANSYS on windows machines with the same licence server and these work correctly. Only the linux installation does not work. I had to set up AEDT with a silent installation. Can this have something to do with it?
Thanks,
Tomas
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3744
2570
1787
1236
594
