Discovery Import
Discovery Import
Not getting good results
    • rinaldi
      What's the GPU that is used for solving in the Western Europe server?
    • rinaldi
      • Naresh Patre
        rinaldialberto You can check the details by hitting F9 key in Discovery Live session of cloud.
      • rinaldi
        Naresh Patre well the GPU is crazy good. Why I do not get good results? How can I improve the mesh quality? I already set the Speed-Fidelity slider at maximum towards Fidelity. It is using just 2GB of RAM as shown in the attachment. Thanks
      • Naresh Patre
        rinaldialberto There is no such setting for meshing. Is it possible for you to share the model?
      • Naresh Patre
        rinaldialberto Ok I will contact you separately.
    • Naresh Patre
      When I reduced the domain length by 500 mm, I noticed that the change in force in Z direction was ~30%. But when I deleted all the spokes of the wheel (which had very small dimensions as compared to the domain length) and performed same test, I noticed that the change in force in Z direction was ~12 %. So, as mentioned earlier in the forum post, the results get affected based on the "small" details present in the model and the overall length of the domain.
      Discovery Live is intended to understand the trends of results rather than its accuracy. So, if you are more concerned about the accuracy of results, I would recommend using Discovery AIM.
