May 4, 2022 at 2:03 am
ali_elsharkawy
SubscriberI have a rolling problem to simulate and the metal sheet does not plastically deform (if the process was finally solved)
material for roller: structure steel
material for metal sheet: copper alloy
I attached picture of the final deformation and used settings
May 4, 2022 at 2:05 amali_elsharkawy
SubscriberMay 4, 2022 at 2:06 amMay 4, 2022 at 8:29 amMay 5, 2022 at 8:26 pmpeteroznewman
SubscriberAnswered in this thread: https://forum.ansys.com/discussion/38910/2-errors-in-rolling-process-calculation
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8806
4658
3151
1680
1470
