Not sliceable domain in remeshing
    • Larissa333
      Hello,n nI am modeling an extrusion process in a twin-extruder. I am trying to apply the remeshing technique, but the system is returning this message:the remeshing domain defined is not sliceable. Select another method and switch to the surface kinematic condition.nI am selecting the process inlet (orthogonal to the extruder axis) as the inlet plane and the process outlet as the outlet plane. I do not understand what this message means exactly.nnThank you in advance!nnLooking forward for your answer,nLarissa
    • ydai
      Hello Larissa,n For simulating flow through twin-screw extruder, mesh superposition technique (MST) will be applied. You may want to refer to polyflow example 38 Twin screw extruder, for more details.n You can download the polyflow examples from ansys help site: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/prod_page.html?pn=Polyflow&pid=Polyflow&lang=en&prodver=20.2n Hope this helps.n Thanksn Yin
