3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
note autofill field error
    • Roberto
      Hello
      Sheet 1 of 2 autofill notes doesn't work, just drops the page number.
      Correct compilation must be 1 of 2
      Regards
      🛈This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Forum Moderator
      Hello Roberto
      Let me check.
      Regards.
      Forum Moderator
      Hello Roberto
      If my understanding is correct, you are using number of sheets (english translation) instead of sheet number.
      This will give the number of sheets your file has.
      This gives the sheet number, although not as 1/2 and 2/2, but just as numbers, 1,2.. etc.
      Let me know if my understanding of your issue is correct.
      Regards.
      • Roberto
        Charudatta Bandgar Yes this is the command I use but it doesn't work
        Once it works it said 1 of 2 ,,,, 2 of 2
        if I use the default field of a ready-made drawing format it works otherwise if I create it from new it doesn't work
        Video link https://www.screencast.com/t/5MIL4glv
        Forum Moderator
        Roberto As far as I understand, this is the expected behaviour. Let me still check with the team, I will get back to you.
      • Roberto
        Hello
        Charudatta Bandgar If this is the expected behavior it would make no sense to have two equal fields one called sheets , and another number of sheets.
        I remember that in the old versions it wasn't like this and there was a difference
        regards
    • Roberto
      Hello Charudatta Bandgar
      you have some news?
      Regards
Viewing 3 reply threads
