Nucleate Boiling Using ANSYS FLUENT .
    • mrmogan
      sir
      I re- created axisymmetric model in DESIGN MODELLING and successfully created parameters.
      I calculated solution for NUCLEATE FLOW BOILING in Fluent.
      Solution is not converged.
      Error statements:
      # Divergence detected in AMG for pressure coupled: protective actions enabled!
      # Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!
      Experiencing convergence difficulties - temporarily relaxing and trying again...
      Divergence detected in AMG solver: pressure coupled temperature
      Error at host: floating point exception
      Error at Node 0: floating point exception
      case check:
      Review flow specifications at inlet boundaries. Default values detected.(boundary conditions)
      Please anyone help me how to rectify above errors..
      I attached my SETUP file & ANSYS TUTORIAL file in google drive link: https://drive.google.com/file/d/1CBPO3m2ksYqkCVg8TXgLn5jQQ03iedIO/view?usp=sharing
       Thanks
      MOHAN MANNANGATTY
    • Raef.Kobeissi
      Check this tutorial for comparison and let me know if you were able to solve your problem.
      https://youtu.be/nTZpn-FQ5e4
      Cheers
    • Vishnuraja
      Could you please tell me how you solved this
