May 19, 2023 at 7:29 am
Filip Stenström
SubscriberHello,
I wounder where I can see how many integration points (in plane) in each layer of layers when I use SHELL181 elements with the Multilayer Definition. From what I can understand in the Element guide:
"The default number of integration points for each layer is three; however, when a single layer is defined and plasticity is present, the number of integration points is changed to a minimum of five during solution. " However, this is for the " through the thickness of each layer ". I want to know how many integration points are used in plane. If I use SHELL181 with full integration will there be four integration points in plane for each layer? -
May 22, 2023 at 8:30 pm
mjmiddle
Ansys EmployeeThis is an element output quantity for shell181 as shown in table 181.1 in the element reference for shell181:
The footnote 5 says you need to use OUTRES,LOCI,ALL
Then you can use "General Postproc > List Results > Element Solution > Geometry > Element integration point." I did this for one shell181 element 1 mm square with corner at origin in XZ plane:
Potting these:
These were a fraction of 0.21132 along the side length, but this was for a square element.
May 22, 2023 at 8:51 pm
mjmiddle
Ansys EmployeeI tried with a 1x2mm element and the fraction from the end (0.211325) is unchanged.
May 23, 2023 at 12:56 pm
Filip Stenström
SubscriberThanks alot!
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5346
3345
2471
1310
1018
