October 27, 2018 at 7:43 am
abil319
SubscriberHI, In Ansys Maxwell eddy current analysis, the "Number of parallel branches" represent the parallel conductors connected. How does this affect the current passing through the conductors. I assumed that the amp-turns should increase when the parallel branches increases but it seems that the magnetic flux density decreases with the parallel branches
- Maxwell, HFSS or Q3D?
- Error
2630
2110
1335
1110
461
