September 27, 2023 at 12:45 pm
Gloria
SubscriberHi! Does anybody know how I can get the number of variables and equations that my Fluent model is solving?
Thank you in advance!
September 28, 2023 at 10:09 am
Forum ModeratorIt's linked to the models that you have active. What do you want the data for?
September 28, 2023 at 10:15 am
Gloria
SubscriberHello Rob, thank you for your answer. I want the number of variables and equations that my model is solving to give an idea of the magnitude of the model.
September 28, 2023 at 10:55 am
Forum ModeratorVery roughly, you're solving equations equal to the number of data columns that the TUI shows when running, or number of curves on the residual plot. However, each of those equations are made up of many terms.
Number of terms/variables will then come down to solved equations, sub models etc. You'd need to go through every setting, find the equations and then add up all of the terms. But some terms may be a constant, a single value for the whole model, vary with each cell, vary multiple times in an iteration etc. I have no idea how you'd find that number.
What do you want to do with the data? Ie what will you do with it?
September 28, 2023 at 11:10 am
Gloria
SubscriberI need to data in order to state the exact number (I will not do any further calculations with them). Is there any command or option that make these values appear in the command window?
September 28, 2023 at 2:02 pm
Forum ModeratorThere isn't.
8736
4658
3151
1678
1452
