Kampus Merdeka
Kampus Merdeka
Numbering Element and Node
    • raihaneddrin15
      I got info that the capacity of elements or nodes for student can't more than 32000, anyone know how to change it?? thank you
    • Ashish Khemka
      For the latest student version, the number of allowed node count is 128k.
      Ashish Khemka
    • raihaneddrin15
      Thank you Mr. Ashish Khemka, but if the limit is 512k, then what should I fix from this error??
      Kind regards, thank you
    • Ashish Khemka
      My apologies, for Fluids the limit is 512k and for Structural analysis it is 128k.
      Ashish Khemka
    • raihaneddrin15
      Permission to ask again Mr. Ashish Khemka, I have tried changing the total nodes/elements with mesh numbering and it didn't work, so can you please tell me what is the other solution of this problem??
      Kind Regards, Thank you
    • Ashish Khemka
      Reducing the number of nodes should help. Can you try closing and reopening the project and then running the analysis?
      Ashish Khemka
    • raihaneddrin15
      I have tried before, but still can't, after that I try to analyze from the beginning but the result is still same, still can't
      I want to say that I use the Ansys Cloud, not the application
      Kind regards, Thank you
    • Ashish Khemka
      Please let me check and I will let you know.
      Ashish Khemka
    • Mike Rife
      Hi raihaneddrin15
      Right-click the Mesh object and chose to "Clear Generated Data".  The left-click the Mesh object to activate it; then down in its Details menu change the "Element Order" from Program Controlled to Linear.  Now mesh again and check the node/element count.  Should each be less than 128K and can now solve.
      Mike
    • raihaneddrin15
      Thank you very much Mr. Ashish Khemka and Mr. Mike, I will try it
Viewing 9 reply threads
