Systems
Systems
Topics relate to Twin Builder, medini analyze, VRXPERIENCE and more
Numerical analysis of thermal cabin management of using Phase Change Material
    • ABHISHEK KUMAR
      Anyone who has done some energy projects (involving simulation using Ansys fluent and other applications of Ansys ) is required.
    • SRP
      Ansys Fluent can be used to modal PCM. PCM properties must be defined. The enthalpy-porosity approach and the specific heat necessary to alter the material's phase are two of the methods Ansys offers for modelling PCM. You can assess the PCM's efficacy and adjust your cabin design model accordingly.
      Let me know if you have questions related to PCM.
      Thank you.
