Ansys Products
Ansys Products
Nvidia Quadro P4000 GPU Acceleration in Mechanical
    • utkug
      I have a Quadro P4000 and it was not listed as tested GPU acceleration for the Mechanical on 2019 R3. I was looking at the discussions and found the following thread: https://studentcommunity.ansys.com/thread/gpu-acceleration-with-nivida-quadro-p4000/
      I followed the advice provided by Win and Peter and managed to start the simulation with GPU. However, as soon as it started this warning message popped up:
      The Distributed Sparse Matrix Solver was not able to sufficiently
       utilize the GPU accelerator device(s) during this equation solution.
       This can be caused by one or more factors such as: the size of the
       system of equations being solved; using older or less powerful GPU
       hardware relative to the CPU core(s) involved; having insufficient
       available memory on the GPU device.  The check for GPU performance
       terminates for the remainder of this session.
      Initial my model had ~40,000 nodes & ~5,500 HEX20 elements, so I thought to myself maybe it is an issue related to the model size. I decreased the model size however I saw the same error message. Here are the hardware and the problem settings:
      - Intel i9 - 9900k 8 core processors
      - 32 GB of RAM
      - 512 GB of SSD
      - Transient analysis with linear elastic solids, frictionless contacts between adjacent faces, Direct solver, ~40,000 nodes & ~5,500 HEX20 elements
      Any comments or recommendations will be appreciated.
      Utku
    • Wenlong
      Hi Utku,
      I am moving your post to "Installation and Licensing" category so you can get better assistance.
      Wenlong
    • tsiriaks
      Hi Utku,
      Just to make sure it has nothing to do with the project, please try creating a simple cube and use static structural with simple BC's and coarse mesh , then see if you get the same warning/error about GPU.
      If you still see it, try updating your graphics driver to the latest from Nvidia website
      https://www.nvidia.com/Download/index.aspx
      Thanks,
      Win
