November 8, 2018 at 8:37 pm
joeyg
SubscriberHello
I am having troubles importing my model from NX11 learning edition to ANSYS 17.1. I have tried the configuration to link them and run ANSYS directly from NX but it does not work.
Any advice on how to get it to work? Any answers appreciated.
-Joe -
November 8, 2018 at 8:56 pm
tsiriaks
Ansys EmployeeHi Joe,
Are you using ANSYS student version ? Because I think student version doesn't support NX interface with ANSYS.
Here is the list of 'reader' that is supported by student version
Geometry Import:
Neutral format import IGES, STEP
Parasolid (native within ANSYS DesignModeler)
Thank you,
Win
November 8, 2018 at 10:48 pm
pgl
Ansys EmployeeCorrect Win, the free Student products only support neutral file imports and Parasolid. The bi-directional geometry connections are not supported.
Joe: You should be able to export your geometry in Parasolid format from NX11, and you can then import that into the Student Product's "Geometry" application (Spaceclaim or DesignModeler) . However, note that you will need to insure that you adhere to the geometry limits of the student product, for example you can't import a thousand part assembly with tens of thousands of facets.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2524
2066
1279
1096
457
