November 10, 2018 at 12:12 pm
kakutajr
SubscriberHow do you create an object with thickness and height from a polyline in HFSS?
November 12, 2018 at 11:35 am
sana ullah
SubscriberI could'nt understand your question correctly but i think the first thing is that the polyline should be closed in order to make a component. if it is closed then you select all the lines > MOdeler > Surface> Cover lines and then you can make it as an object. I hope this will help, this is how i make objects in Maxwell 2D geometry editor.
regards
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
