Observed temperature data
    • laureano.gonzalez
      I am simulating a physical experiment using Mechanical. The experiment consisted of heat pulses in sediments and I measured temperature propagation and dissipation with continue and point based sensors. Now, I would like to import observed temperature data to compare it with the results of the transient thermal model . Could you please guide me on how to import this type observed data into Mechanical. Thanks in advance.
    • peteroznewman
      Exporting simulation results out of Mechanical then importing them and the experimental data into some other software such as matlab is a typical workflow for making comparisons.
    • laureano.gonzalez
      Thank you.
      I thought Mechanical has these types of post processing functionalities.
