October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow do I get geometry instances in Mechanical from Spaceclaim?
October 18, 2017 at 5:45 am
Arun
Ansys EmployeeIn spaceclaim, it uses components for linked geometry. When copying in Spaceclaim, if you copy bodies, they are independent. If you COPY components, they are linked. So when using the move with CTRL key, you have to select the component, not the body. As far as patterns, these will be linked whether you copy bodies or components. But if you do select only bodies, then it will create components and move the bodies into components. So it still uses components to establish the linked behavior.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
