obtaining pressure distribution by making points in ansys
    • VSK1989
      Dear Team Ansys ,
      Please let me know if I could make any pressure points or lines along the geometry surface .
      I am looking for Cp coefficient of pressure distribution.
      Regards ,
    • Kevin Colburn
      If you have access to EnSight, this is a very easy process. You select the surface(s) that you'd like to inspect. You create a 1D clip through them (Clip via XYZ, or Plane, or any other tool). With the 1D Clip, you can query a variable along that 1D part. That could be Cp.
      This will in effect create 1 point for each intersection of that clipping constraint with the elements of the surface parts. You will effectively automatically get 1 point each each edge of each element which is intersected.
      -Kevin
