April 7, 2023 at 11:54 am
jack forster
SubscriberI am simulating flow into a combustion chamber. I am trying to obtain the swirl number at multiple cross sectional planes. I have compiled the UDF source code with no errors but I do not know how to extract the value at a specific plane. Is this done within report definitions?
This is the UDF code I am using:
include "udf.h"
DEFINE_ON_DEMAND(calculate_swirl_number)
Domain*d;
Thread *t;
cell_t c;
real rho, mu, U_axial, U_radial, U_circumferential, Swirl_Number;
real angular_momentum = 0.0, axial_momentum = 0.0;
d = Get_Domain(1);
/* Get the density and viscosity of the fluid */
rho = RP_Get_Real("operating-density");
mu = RP_Get_Real("operating-viscosity");
/* Loop over all cells in all threads */
thread_loop_c (t, d)
begin_c_loop (c, t)
/* Get the axial, radial, and circumferential velocities */
U_axial = C_U(c,t);
U_radial = C_V(c,t);
U_circumferential = C_W(c,t);
/* Calculate the angular momentum and axial momentum */
axial_momentum += rho * U_axial * C_VOLUME(c,t);
angular_momentum += rho * (C_UDMI(c,t,0)) * C_VOLUME(c,t);
end_c_loop (c, t)
/* Calculate the swirl number */
Swirl_Number = 2 * angular_momentum / (axial_momentum * mu);
/* Print the swirl number to the console */
Message("Swirl Number: %g\n", Swirl_Number);
}Any help would be greatly appreciated.
April 11, 2023 at 2:29 pm
Ansys EmployeeHave you looked in the Contour plots? Under Velocity you'll find axial & tangential velocity. In Mesh you'll find Axial and Radial positions. These are relative to the local cell zone axis (set in the Cell Zone panel(s)). You may want a Custom Field Function. You can then report these using the surface reports and/or plot the contours.
5162
3251
2443
