September 16, 2022 at 3:35 pm
JaySmall
SubscriberI've been running scramjet simulations for my research work for several months on a coarse mesh. The simulations usually run without any issues. Recently, I created a finer mesh with improvements to key areas. This increases the total cells from 2 million to approximately 9.8 million. On the finer mesh, the simulation will run for 100-200 iterations before crashing and producing errors such as:
Node 28: Process 14072: Received signal SIGSEGV.999999: mpt_accept: error: accept failed: No error (repeated multiple times)
999999: mpt_accept: error: accept failed: Abort(138030991) on node 31 (rank 31 in comm 0): Fatal error in PMPI_Waitall: Other MPI error, error stack:
PMPI_Waitall(346)..............: MPI_Waitall(count=6, req_array=000000387A7FDE00, status_array=000000387A7FDF00) failed
MPIR_Waitall(174)..............:
MPIR_Waitall_impl(55)..........:
MPIDI_Progress_test(185).......:
MPIDI_OFI_handle_cq_error(1042): OFI poll failed (netmod\\ofi\\ofi_events.c:1042:MPIDI_OFI_handle_c q_error:Unknown error)
Abort(70922127) on node 21 (rank 21 in comm 0): Fatal error in PMPI_Waitall: Other MPI error, error stack:
PMPI_Waitall(346)..............: MPI_Waitall(count=16, req_array=000000E02DBFE170, status_array=000000E02DBFE270) failed
The fl process could not be started.I've talked to Ansys personnel who asked that I confirm the intel MPI was being used, and it has been confirmed using the .trn file.
I'm running the simulations parallel on a machine with the following hardware:
AMD Threadripper Pro 3975WX 32 core
128 Gb DDR4 Memory
Does anyone have experience with this type of error, and possibly how to go about fixing the issue? Thank you in advance for your help. -
September 28, 2022 at 1:02 pm
Nikhil Narale
Ansys EmployeeHello,
Is this a case specific issue? Can you try a different case (with different geometry) and create a mesh with a cell count close to 9.8 M? Check if the same error comes up.
Nikhil
2644
2110
1335
1112
461
