August 4, 2022 at 3:49 am
August 4, 2022 at 5:14 am
Devendra Badgujar
Forum ModeratorHi Roberto
Can you please elaborate to understand the problem better? Please can you mention the steps you took when you received this error.
Regards.
August 4, 2022 at 5:19 am
Roberto
SubscriberHello Devendra Badgujar
I activated Excels from SpaceClaim add-ons (from options)
Regards
August 10, 2022 at 9:17 am
Devendra Badgujar
This is an add-in we provide with the install, and will be updated for 2023.1 to use a more recent API version. This is just an informational message that your are seeing, and the add-in should work normally.
Regards.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8740
4658
3151
1678
1452
