August 7, 2018 at 5:20 am
tsunada
SubscriberI tried attached file, but while not connecting internet, spaceclaim didn't work.
tsunada
August 7, 2018 at 5:42 am
Naresh Patre
Ansys EmployeeTsunada After downloading and copying the attached file, you need to be connected to the internet for the first time. Afterward, you can work offline. -
August 7, 2018 at 6:17 am
tsunada
Subscriber216272 Naresh Patre For the first time I conneted Internet, SP works. Then disconnect internet, SP works, But Over 24Hour Later SP does not work. Some time limit exists? -
August 7, 2018 at 6:26 am
Naresh Patre
Ansys EmployeeTsunada Are you using the patch mentioned in this post? If yes, can you try installing the latest Discovery build that is available under downloads section?
Secondly, what is your Windows username? Does it contain any special character?
August 7, 2018 at 7:58 am
tsunada
SubscriberNaresh Patre I used the patch mentioned in this post. And download latest build version and installed.
Windows user Name is AP100v4, doesnt contain any special character.
Naresh Patre
Ansys EmployeeTsunada Did you install the latest version and then copied the patch from this post in the latest version? If that is the case, then you don't need to copy the patch in the latest version since it already has the patch build into it.
Anyways, can you type %temp% in Windows Search and go inside .ansys folder. Locate .log file starting with ansysls_client* and send it to Discovery Support Team ?
August 7, 2018 at 8:59 am
tsunada
SubscriberNaresh Patre I dont know Widows Search. Is it same Explorer Search?
I tried Explorer, but cant find ansys folder.
August 7, 2018 at 9:18 am
Naresh Patre
I found dir C:\Users\AP100\AppData\Local\Temp\.ansys
I had sent ansysls_client.AP100.log to support team.
August 7, 2018 at 11:56 am
Naresh Patre
Ansys EmployeeHello Tsunada
We did not recieve any file. Can you please resend the file to ansys-discovery-support@ansys.com
August 8, 2018 at 12:20 am
tsunada
Sorry I had sent to local support team not to ansys-discover-support team.
I will new send user log.
It is included
(1)While internet connecting, sc works
(2)Right After disconnect internet ,sc works
(3)Over one day after disconnect internet, sc doesn’t work
August 28, 2018 at 10:46 am
Naresh Patre
Ansys EmployeeThis issue is related to MAC address which has been fixed in R19.2 version. Once released, you will need to deactivate and re-activate to update the device id.
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
5200
3275
2457
