July 15, 2019 at 6:11 pm
BiomedModeller
SubscriberDear all,
I am trying to assign Windkessel model (RCR) to an outlet of an artery. To do this without Fortran routines, I require to access to the value of pressure in last time step. There is a workaround using "Probe" function and monitor points. However, it cannot be used to define an expression to set the boundary condition. Any hint how to solve this issue?
Thanks -
July 16, 2019 at 5:04 am
DrAmine
Ansys EmployeeYou can use workaround using arithmetic average over last two time steps with the probe expression. As ASC you can check that on the portal. -
July 16, 2019 at 1:56 pm
BiomedModeller
SubscriberDear Amine,
Thanks for the reply.
I did do that and it worked well. The problem is CFX does not allow me to use it as an expression to define boundary condition. I want to use the value of old pressure in outlet BC definition and CFX says you cannot use probe in BC definition. What do you suggest? -
July 16, 2019 at 3:28 pm
DrAmine
Ansys EmployeeTry assigning that To algebraic variable. If it does not work let us know. -
July 16, 2019 at 5:55 pm
BiomedModeller
SubscriberWe have done that as well. Gives the return code 1 error bellow:
| User Defined Monitor Information |
Monitor Point: MP current Q
Arithmetic Sum
Monitor Point: MP current P
Arithmetic Sum
| Writing crash recovery file |
Details of error:-
Error detected by routine MAKDAT
CDANAM = LVAR CDTYPE = INTR ISIZE = 123
CRESLT = OLD
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
July 16, 2019 at 5:56 pm
BiomedModeller
SubscriberThe Ansys manual emphasizes for the probe that:
Note: The probe function does not calculate a value for a statistic until the defined interval is complete. As a result, a “probe” function that retrieves a statistic from an expression-based monitor:
- Should not be used in a CEL expression for a quantity that is required at all times, for example, a boundary condition.
July 22, 2019 at 2:37 pm
BiomedModeller
SubscriberAny update please?
July 23, 2019 at 10:51 am
DrAmine
Ansys EmployeeYou can provide a good starting value for that variable if used all time.
If still not helping you will need to use User Fortran.
3744
2572
1793
1236
594
