December 12, 2018 at 4:50 pm
lucaavv
SubscriberHi
I would like to open a project that I made in ANSYS 19.2 student version with ANSYS 17 but i receive an error similar to "This project has
been made with an older version and can't be opened".
How can I solve it?
If I write a FLUENT case I will be able to open the "new version" case with the "old version" software?
December 13, 2018 at 5:03 am
Keyur Kanade
Ansys Employeeyes, please write *.cas or *.cas.gz file from Fluent !9.2. You will be able to read it in Fluent R17.0
Depending on the set up, you may need to redo some steps in set up in R17.0.
Please use standalone Fluent. i.e. go to Windows Start Menu and type Fluent. Then open Fluent.
If this helps you, please mark it as 'is solution' to help others on forum.
December 13, 2018 at 6:37 am
lucaavv
SubscriberThank you
- legend min and max
- Ensight hot iron palette from an image
- Crash with Exit code 1073741819
- older version
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- What are the OpenGL drivers supported by SCADE Display KCG?
- What are the target language supported by the SCADE code generators?
- FLUENT APPLICATIION ERROR
- save data error
2524
2066
1285
1096
459
