Discovery Import
Discovery Import
On output of drag force in fluid analysis
    • fuyu-m
      I would like to know the drag force on objects when I place an object in the flow.
      Can Discovery Live output drag force?
      I know that Discovery Live can output "Normal · Direction" and "Direction".
      Does [Pressure] [Normal · Direction] not include drag force, does [Direction] include drag force?
      If my recognition is correct, is the result of subtracting [Normal · Direction] from [Direction] of [Pressure] equal to drag force?
      If this method is wrong, please tell me how to output drag force.
      Thank you.
    • Naresh Patre
      Hello Wintercat I will also get back to you on this question.
      • fuyu-m
        Naresh Patre , Thank you very much.
        I appreciate being able to give you an answer.
    • Naresh Patre
      Hello Wintercat
      You can insert calculations to measure forces.  You can use Total Force in X, Y, or Z to find the net force in that direction.
      • fuyu-m
        Naresh Patre , Thank you for your advice.
        I will try out the method I taught.
        Thank you.
