April 19, 2023 at 12:15 pm
Yao Xiao
SubscriberFor the one-dimensional height ratio grating as shown in the figure below, when using rcwa for simulation, you should choose 2D or 3D. Because it is very long in the y direction, not periodic. Periodicity is only in the x direction. In the case of photonic crystals, both x and y are periodic, so three-dimensional is used. How that 1D raster should set the simulated dimension. I chose 2D but it doesn’t converge. I choose 3D to get results quickly but it’s wrong.
April 19, 2023 at 6:21 pm
Guilin Sun
Ansys EmployeeRCWA solves periodic problems. So if the length in y is long, you should use 2D and ignore its effect of limited size. 3D will require y direction periodic, the same as 2D since it assumes y is infinitely lone.
April 20, 2023 at 7:52 am
April 20, 2023 at 7:58 am
April 20, 2023 at 10:06 pm
Guilin Sun
Ansys EmployeeYou may need to reload the file if it is not corrupted, copy the geometry to a new project and run it again. For faster testing, instead of using 201 frequency points, simply use 21 points, and test again. Make sure the file can run.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5340
3345
2471
